集成环信demo里面的类库之后,运行不了项目,提示\jdk1.8.0_20\bin\java.exe'' finished with non-zero exit value 2
1集成环信3.0中libs下的类库之后
提示
Q:Error:Execution failed for task ':app:dexDebug'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command 'C:\Program Files\Java\jdk1.8.0_20\bin\java.exe'' finished with non-zero exit value 2
然后,我修改了gradle文件
defaultConfig {
    multiDexEnabled true
现在的异常是:
Error:Execution failed for task ':app:packageAllDebugClassesForMultiDex'.
> java.util.zip.ZipException: duplicate entry: android/support/v4/provider/TreeDocumentFile.class
你看下是否是和V4包里面的某个包冲突,更改下包名,在试试看下
要回复问题请先登录注册
